So I got my Gen 1 with a PCV installed. Added a Launch Master and I've got no fuel pump prime/no start.
Do you have to have the ignition control module to use the PCV and MSD launch master together? With both installed I get the active light when I test the launch master clutch ground install per instructions, but I can't start with both installed. I've had PCV installed for a while.
I figured PCV to injectors with launch master to coils would be fine set up like that. Apparently not.
