And just how would you know that?
Oh, by the way, how did the DVD turn out? I'm looking forward to learning more about the SD Card recording devices!
Uh....I have a 30 mile long dyno here in Florida..we have been over this..
GPS as well as Iphone show same , factory speedo progressivley becomes more and more off as you get along lil doggie !
Still cant figure out how to burn quicktime/mpeg to DVD for true HD picture.
If I convert to wmv then I lose my intent of getting clarity on disc.
Have not tried to put it on usb but other poster in my thread seemed like he knows so I did not pursue it.
for now I'm stuck.
Sorry Jethro for the sidetrack
back to your question.
You need to get an accurate figure on your true speed 1st.
Then use one way to unlock factory limiter which there are many.
Most of these will alow you to raise factory rev limiter as well as remove speed restriction.
When you do a true 185 believe me the diff of 5mph more wont be discernable.
150-160 up to 170 fine but pushin past that you need space both to get there and slow down mostly.
The diff between 170 and 180s or more is significant in drag and other factors.
You can get from 100 to 160+ on the speedo in 6-7 secs.
It takes a lot longer than that to react and or slow down and stop.
And no tuf I am not posting the video.
