arthur39
in my quest to build a new turbo system for the busa, i read velocity stacks in the plenum are a good mod. I am building the plenum now, and have a set of 48mm id velocity stacks that are 72mm long appx 2 3/4", the inside of the plenum is 3 inches deep, about 5/8 to 3/4 of an inch will be outside the plenum for the hose clamps wich will leave about 1inch above the stacks for flow.
my question is will this help for driveabiliy for around town? I am looking for a very streetable busa, 80 percent of time will be under 5g's the rest will be for fun I figure since the longer stacks help low and mid torque I should use them for putting around, I will be also loosing bottom end due to .080 spacer, so it should help the low end out a little better? Or.... should I cut the stacks even shorter or just do away with them and stick a 2" tube flush with the bottom? Anything? thank you for your assistance
8lbs boost
8lbs boost
