**Posted this thread in other forums, hunting down the ones who attempted or successfully made it happen**
Hi all,
So Pressure Stage.... Did anyone try this? If I'll go the dry sump route, I would add pressure stage cause it doesn't make sense to me otherwise. I received few responses from NRL and others saying I don't need it. While I respect those responses, I just need to know if anyone out there actually tried it?
Dailey built dry sump with pressure stage for Hayabusa but can anyone share the feedback? I need some feedback cause I'm running uphill races (50 degree slope) up to 10 seconds per pass at WOT full load with paddle tires on a Turbo'ed (close to 30 psi) hayabusa powered sandrail so positive oil pressure all the way to a point where I have to empty the catch can I have on the crankcase breather on every pass otherwise, I would overflow.
I checked the manual but I'm not sure if this is correct. If I remove the oil pump, How the scavenge pump shaft would rotate. It looks like the scavenge pump shaft which replaces the water pump shaft is driven by the oil pump shaft? So how this is going to work? Please have a look at the attached page from the manual.
Thanks,
Abdulla
Hi all,
Thanks,
Abdulla
