Anything I'm forgetting?
89mustang
I just my swing arm on yesterday! I've ordered an air tech 6+ street tail as well as a 45 tooth rear sprocket. I have the brake line and extra chain links. Do I need the tiger tail for it? If so which one?
Thanks in advance!
Tiger Racing
You will have to do some trimming. I used a jig saw with a blade for metal. I painted mine black and then covered it in velcro to put all the electronics and ECU back on. I also got the battery case to hold it nice and tight.
Tiger Racing
Did you replace your shock? You will need to. I also got an integrated tail light because I was too lazy to cut holes in the tail. It was a ***** to make brackets to hold that tail light in the street tail. It took patience to cut the tail to accept the stock tail light.
Tiger Racing
Tiger Racing
Which tiger tail do I need? The standard or extended?
Thank you guys for the suggestions! I'm going to get a feel for it first before I add an air shifter. I've been looking at the cycletek which was Dennis suggested. I have a strap and lowering links for it. I have to buy a new stand because the arm doesn't have spools. I'm going to slam it down before I head to the track.
gnbrett I'd love to turbo it. When it comes to power adders it'll make your head spin. I did email rcc and asked about a stage 1 kit
I'm running MR12 in the bike now and it picked up quite well with that. If I did anything I'm leaning towards nitrous a 40 shot. I have 2 tunes loaded on the Ecu, is there any way to get 3?
I did a quick search on the R1 throttle tube. It'll be my next mod for sure!
I have a stock seat to cut down. Last year I ran with no seat at all.
Tiger Racing
You will have to do some trimming .
I used a jig saw with a blade for metal .
in Velcro to put all the electronics
and ECU back on . . .
Tiger Racing
Did you replace your shock ?
You will need to .
cut holes in the tail .
It was a biatch to make brackets
to hold that tail light in the street tail .
:banana:
