Aly Kabil
Hello everyone,
I am running RCC stage two on my 2008 busa with stock engine ( I have the stage two injectors and the fuel pump and the fuel rail and ball bearing turbo 53 lbs 520 HP with modified , but he sent for me bin file for stock engine with all this setup) and I have something strange between 5000 RPM and 7000 RPM I feel that something hold the bike and after 7000 it start to accelerate also I tried to log some runs and I have something so strange that my manifold pressure and atmospheric pressure are always the same under full boost and 100% TPS
Any one here have same problem before
Also I attached fuel pressure gauge to see the fuel pressure while riding and when I open the ignition the pressure is about 39 PSI but when I start the engine it about 43-44 PSI, is that normal
Hope someone can help here
