Aux Fuse Box
slime
Hey folks, I'm planning to add a fuse box to power all my gadgets (gps,radar detector,heated gear, etc)Just wondering about some options, suggestions from anyone that's done this.Anyone got a good source for one? Also, wondering if I can trigger that fuse box with a relay from the extra plug behind the headlight(low beam side) without any issues? I may add an HID later too.(Probably not before my trip to arkansas and missouri this comming weekend) but soon!(Anybody got a good route from little rock,ak to perryville,mo
This exact thing has been discussed several times in the last couple weeks. LOL
I am using a Painless Wiring product called Circuit Boss. I am using the 7 circuit system that is weather resistant. It comes prewired, so all you have to do is connect to your power source and trigger, this will give you 3 always hot, and 4 switched. It comes with a relay you can connect to the connector you're referring to in the nose.
I plan to finish up my install this weekend.
Good luck.
https://www.hayabusa.org/forums/?act=ST;f=6;t=91150;hl=8
https://www.hayabusa.org/forums/?act=ST;f=6;t=65430;hl=
