Captain Carefree
Greetings from NZ
I have a 2016 'Busa and am thinking about fitting auxiliary driving lights as a lot of our roads a single or dual carriage ways, often with sod all lighting, white lines, marker posts etc and at night bloody hard to where the road goes or doesn't.
There is a wide range of LEDs on the market but most appear to be mounted down low on the front fender or brake caliper mount.
Has anyone fitted lights up higher, say by making a bracket to fit where the mirrors are mounted and mounting the LEDs off that bracket. Easy enough to do..
I don't need plate sized behemoths, just a set small enough to fit between the screen and mirror above the mirror stalk yet strong enough to singe the fur off a possum at 200m
any ideas? Anyone done this and if so what lights did you use?
regards
Chris
regards
Chris
