Auxiliary Plug in Nose?
Fireman6615
OK I known this plug is supposed to be there from all the reading I have done here. On an 06 LE where exactly is it and how do I get to it? I plan on buying the Plug and Play accessoy power harness from Smithabusa and was just trying to get a visual on this plug. Do I have to pull the nose off or is there a way to reach in and plug it in? Thanks.
It is usually a brown plug and you should be able to access it by pulling your inners and cluster, rather than pulling the whole nose.
On my Gen 2 it was completely obvious which plug was unused once you get the gauges out of the way.. :beerchug:
Mine is a Generation 1, I know what the plug looks like and I know where it should be, I just wasn't sure about the best and easiest route to get to it. So pulling the gauges is the easiest?
Dont quote me on this because I need someone to verify, but I thought on the gen I the aux plug was on the right side next to the turn signal. On the Gen II it is behind the gauge cluster.
Small black 2 pin plug and its located just above the t=right turn signal.
It has a brown wire, and a black/white wire in it!
