Axel grease
MN72Busa
Formerly known as "Zuki"
Well changed out the wheels, and got to thinking about the axels. Should I use some sort of special grease on the front and rear axels?
I used a little Amsoil 10w40 synthectic on the axels, but wondering if I should use some form of grease instead before I loctite all the bolts down, or is the oil good enough
I usually just put a light coat of oil or smear light coat of grease as the amount of tolerance there will take all it off anyways.
I usually just smear on a little grease and reassemble the wheel
the axle doesn't move(no rotation), the bearings inner race doesn't move(no rotation on the axle) greasing up the axle...pointless. Maybe a pinch to ease installation,help prevent corrosian...
RSD.
  RSD.
I only use it so the axle slides in easier...its only aluminum alloy and there is no reason to chew it up
Careful this a G rated channel....I wouldn't want to hit the "button"
"Report this post to a moderator"
you would have to censor yourself
I have never used anything on the axles and they still look the same as the first time I had them out.
Its not a wear issue...just some things go together with a little lube
you don't need to put anything on your axle to install it....more of a personal preference kinda thing.
I would have never thought this thread would have went this way...ok, I remember where I am now
