If you have an '02 or later model Busa there is no tool to remove the front axle. I made my own tool by using one of the large size allen wrenches (18mm I think...) and welding a 22mm nut to the end of it. It works great and can be stored inside the tool bag in the hump.
Get a 16mm bolt and two 16mm nuts from Lowes, about $4 total. The 16mm equals a 24mm head size which is exactly what you need. Tighten the two nuts down onto the bolt with some locktite and your done.
Its a 24 mm allen on 02 and newer.I did the same thing as those other guys but I used a bolt and nut that had 15/16 heads. I have now bought 22 and 24 mm allen sockets from snap on. Check out Veltunes site Tom has pictures and info about how to make the nut and bolt tool.
