Baby Ninja has problems
GSXTacy
Mr. January
Last night my Spoiled Busa layed her 250 down in a parking lot. 0 MPH fall off the kickstand. When we picked it up, it would not start. Thought the engine was flooded so we waited a while. I started after a while with the choke on and thats the only way it would run. I ran it around the block a few times and it never got better. Its like its starving for fuel now after about 4K rpms. I let things dry out till this morning. Same thing. What could have happend when it fell on the right side? I dont even know where to look. I'm used to working on my busa with fuel injection, not the carbs. The bike is an 02 with 3800 miles. The bike was running fine to that point, we had been out about an hour. Thanks in advance for any help.
Somewhere along the line when the bike tipped over it could have flooded either the spark plugs or maybe the pilot jet screws got stuck
<a href="http://faq.ninja250.org/wiki/Troubleshooting" target="_blank">Try this link...
</a>
The float might be stuck in the carb or some dirt got into it...shut off the fuel...then start it up and run it dry. Then tap on the carb with a hammer (the handle of a hammer
)...then turn the fuel back on and fire it up
I got it, its amazing what happens when you ride the hell out of it!
prolly stirred up some junk from the tank and it got stuck in one of the jets...
I have seen this many, many times before.
Try some Knotty Head Fish oil extract.
Just a tad into the crank case and you'll be good to go!
(YH2K @ Aug. 21 2007,14:54) I have seen this many, many times before.
can we get that at Wally World or do we have to go to NC?
Semi, I have it on good sources to be a Robbinsville exclusive
