Sounds like the problem.pair mod time.
On a stock bike if you have a exhaust leak....on deacceleration you can suck in outside air into the ex system and when mixed with the unburned fuel in the exhaust....it will back fire. It could be a loose connection at the mide pipes or a small leak at the head.If it is completely stock, no exhaust mods, it should not backfire.
exactly, it should not backfireOn a stock bike if you have a exhaust leak....on deacceleration you can suck in outside air into the ex system and when mixed with the unburned fuel in the exhaust....it will back fire. It could be a loose connection at the mide pipes or a small leak at the head.If it is completely stock, no exhaust mods, it should not backfire.
