DanS
Bad Power Commander V ?
Installed Brock CT megaphone along with PC V with Brock's street map. Bike fired up and within 1 minute began to idle very poorly and FI light came on. Read codes and C34 and C35 came up. Service manual states
"CKP sensor (pick up coil) signal is produced but fuel injecor signal is interrupted 4 times or more continuously."
Check for
"primary fuel injector wiring/coupler connection, power supply to the injector."
I unplugged the connectors on injectors 3 & 4 and reconnected them three or four times. Restarted bike and the same thing happened. I then took the PC V out of the system, started bike and it idled perfectly. I let it idle for a few min. killled the bike and restarted it. Bike runs fine with out the PC V.
I presume it must be a bad PC V. What do you guys think?
Sorry for crappy cell phone pic
Check for
