Kevin Jones
Ok, I have reviewed the wiring diagram (2002 gen 1 US model) and it appears to me that there is only one hot lead (brown) going to each bulb, with 2 separate grounds to each bulb, which to me is baffling. 1 with greater resistance (running lights), 1 with less resistance? (brake light). Is this correct? Both the white/black and the black/white have continuity to ground with key on or off. The brown wire has 11-12 volts. With bulbs in (spring loaded 20/5w), the only lights that work are the brake lights. No running lights. I started working this issue at about 8 last night, cleaned up the sockets, worked on the spring/contacts, did everything simple I could think of along with testing and stayed at it for about 3 hours. I am in doubt about the white/black. Effectively that is the "ground" for the brake light but am I wrong? Is this another hot that somehow is grounded? All turn signals work. I really needed another set of eyes, I got too tired I think. When I put the bulb in backwards, short pin in long slot, the brake light comes on full blast, but I cannot, simply cannot get the running 5w to work.
Or should I ****can the whole spring loaded bulb and put in some LED type replacement socket.
