Balancer removal tested with dyno.
Here is some more information about how to take the busa performace a little step higher. All testing was done with a Dynojet 250. First the busa was dynoed just before the balancer was to be removed. Then the balancer was removed and the bike was then dynoed. And the performance gain was just two(2)rwhp wich is what you would expect if you look at the small unit the balancer is with little counterweights. A 2rwhp gain can also be made if you lube your chain and that mod is much easier and less messy.
[This message has been edited by TOJ (edited 21 August 1999).]
