Batteries??
drnick
Yeah I know do a search,did that,couldn't find an answer...2008 takes a YTX12-BS,10 amp,is there another batt.,that has more CCA then the stock OEM Batt....that will fit under the seat???...I know on the gen. 1,you could install a bigger batt.,can you do that on Gen.2??? THX Dr.N
Yuasa YTX12-BS cross references to:
Exide 12-BS
Deka ETX12
Delco GTX12-BS
Interstate CYTX12-BS
GS-Ztong Yee GTX12-BS
Motocross B3RH2S
Napa 740-1866
Sears 44016
Walmart ES12BS
Yacht CTX12-BS
MotoBatt MBXT12U
We just carry the MotoBatts & Yuasa
Btw, on the Gen-I, we use the Fast by Gast battery, but requires cutting the seat pan out a little to get it to fit.
Other thing you can look at is more exotic batteries (think about $250) which have lots of CCA.
CCA is now at about 240 & fits in the palm of your hand.
Thanks Pashnit.... motobatt mbtx12u is the replacement for yuasa ytx12-bs?...who makes motobatt,and is it a lead/acid type?
