Battery Charging Question
Kuhrazy
I have a NOCO Genius 4 bank Charger, and I'd like to pre wire it into my bike.
It comes with the normal screw down connectors, but my bike is a 24v system, and the secondary battery has tabs, and not posts to screw to.
My questions is: Can I splice the ends, and put the charger inline with the existing wiring using a tab connector?
It seems like no one has an answer. And I'm afraid to try it in case I crap out one of my relays for the 24v starting system.
Anyone???
Does your 24 volt system charge it self? Or do you need to charge the batteries separately?
It is the stock system that is installed on the bike, with a Tiger Racing 24v system wired in.
Secondary 10amp 12 volt battery in a battery tray in the subframe, with a 12 volt standard battery in the battery tray under seat.
I dont get to ride relegiously and I dont want to keep buying batteries or pulling them out of the bike to charge.
The secondary battery does not have post terminals, but tab terminals.
This is the battery that was sent with the Tiger Racing kit. http://www.manitobabattery.com/linked/ub1280.pdf
I just want to know if I can run the trickle charger in line with the tabs.
