metalli445
I have a 02 Hayabusa and I've recently had trouble with the battery. At least I think it's the battery. First off, it hasn't been replaced for awhile and when I charged it over the winter I had the charger on a 12volt 2 amp setting. Today I was browsing the web and I read that your not supposed to charge this type of battery on anything more then 1.5 Amp's. I don't know if the 2 Amp setting really hurt that battery.
The reason I'm searching for a battery is because on my last trip (45 Min) I shut the bike off and when I went to start it I didn't have enough juice to crank the engine over. I got a hotshot and the thing ran strong until I got back home which then it wouldn't start again. I took the battery to a motorcycle shop to get it load tested. They said it was at about half life. I charged the battery, hooked it up to the bike, started the bike and reved it to 4500 RPM's where I was getting 14.5V at the battery posts. Since I got this reading I think the alternator is doing its job. What do you think?
The stock battery is 176 CCA. Sometimes I feel like the bike struggles to turn the engine over. I was thinking a battery with more Cold Cranking Amps would make it easier on the bike. I've found one battery that has 235 CCA and another that has 380 CCA. If I went with one of these would I hurt anything? Since I have a stock alternator, could it keep up charging this battery? Thanks!
