BEGI Connections
65Cobra
This is what I get for taking on too much, then trying to pick up later. :banghead:
On the BEGI FMU, I can't remember which of the 2 large ports is IN and which is OUT. One is a little higher than the other. Could someone please let me know?
Also, regarding the 2 small ports... is there any difference between them? Does it matter which one I connect the fuel pressure gauge to?
I promise to write it down... thanks.
I forgot to mention, I have the Multi-Role MR2035 version which is the larger unit that incorporates a 1:1 regulator on the bottom. The center section where the fittings connect is round.
Should be tiny little marks indicating which is in and which is out. I thought mine wasn't labled, asked online, they sais it was marked, I looked again and found the markings.
Posted via Mobile Device
Thanks for the info... I took a look at mine again for anything that might differentiate one from the other, or at least identify one of them, but there aren't any marks at all. I recall when I received mine, and that was directly from Bell Engineering, he had marked the IN port with a permanent marker but that's long gone. I was going to just call him but then I found an earlier picture and it showed enough to give me the answer. With the R/R adjustor pointing up, the higher of the two large ports is IN... the lower is OUT.
