I have heard of a charging system upgrade, but read it only made a minor difference.
We use re-wound stators that put out an additional voltage while charging. We have tested them on three bikes with solid results. Give is a call for details.Link someone? Real curious if there is a way to boost the electrical output of the bike? Busa is not known for it's charging output, at least not mine.
Prices seem pretty reasonable.
Takes you from 400 to 500 watt output for a buck 25. That might be the answer and forget about adding a battery.
