Hi there berksenbay , welcome to the Org. and congrats on your choice of Busa !!
Firstly there are many ways to go for mods , you may want more a focused Busa , with lowered stance and drag race winning potential , or you may want a standard height do it all well bike , or you might want something a little lighter and even better handling , All will want some updates to front brakes . I might add , your 2012 is the same as the 2008 +Busa update , known as the Gen 2 . 2013 the Busa Gen 2 got ABS and overall better brake system . I will make recommendations for all round street enhanced handling and weight saving / power increasing , readily available exhaust .
Exhaust , you could go ultra light and good power gains , Brocks , CT series , either the full CT system 4-1 or the 4-2-1-2 Dual CT system , or CT Meg short system 4-1 , all are CT are titanium , all class leading lightness and good to excellent power . Add a PC5 , and get your ECU flashed .
Akrapovic , exhaust are also class leaders in BHP , and are a good weight saving , even in stainless . Either is a good choice . Perhaps more positive gains alround from this choice .
Secondly , I would be thinking seriously about wheels , and there is a number of good options the Org. has covered in detail... really you must decide if you want Magnesium , forged Aluminum , Carbon Fiber or lighter factory items ( namely R1 Yamaha ) , for your material choice , then check prices and brands packages to fit Gen 2 Busa . Wheels are not a urgent necessity , but will be a major package gain for the bikes unsprung weight , and combined with suspension can be the ultimate all road conquering handling mod , and generally enhance your Busa 's look . You can be looking at anything up to a huge chunk $ dissapearing with this purchase .
Suspension is always a good update especially if you enjoy your corners . Lots of companies make good rear shocks for Busa , Any you choose will have to be fitted with the correct spring for your weight , when you order / buy it . The forks can be fitted with a spring kit , or cartridge kit , again fitment to your weight . You could lash out on a entire fork set , but best value for $ is to get your stock fork kitted out .
Now your Busa's brakes lack feel out of the factory , the Tokico units will work okay however , but need a couple of thing done . Of note , most any 108mm spaced 4 piston aftermarket caliper should be able to fit up to stock forks , and the Busa 2013+ Brembo cast 1 piece ( M50 ??) for example . can be used and are good value new or second hand . The same explanation as below would also apply to the these units .
We will presume you are going to keep the original Tokico's , so , a new set of organic Kevlar pads can be an option (good on disc wear ) , or HH sintered pads for serious stopping and disc wear . ( Really discs are a part that wears out sooner or later and should be accepted as such ) . The brake lines will need to be replaced with some braided steel lines , and then the master cylinder pump will need replacing , and there are a couple of choices , either fitted up with hydraulic pressure switch or mechanical activated switch . The other option for brakes , is the entire brake system updated to some caliper / master cylinder pump package . There are a few choices , but this is generally expensive $ . All this is searchable on the Org. try searching tags of what you are interested in , do some research , plan your approach / attack and you will be rewarded with the right choices . In the meantime , you can acquaint yourself with your new to you Busa , do your checks and enjoy bro . Here is a couple of pics of my 2012 L2 Hayabusa
