Hello All
First post here so please bare with me on this:
I have seen a similar problem i have on this forum here:
I have had my motor ( 2000 RY ) built up using the following parts:
1397 pistons by wisco
head ported and flowed
yoshi stage 1 cams
yuasa ytx14s battery
high volume oil pump gear
billett cam chain tensioner
new cam chain
i run the motor in for 1,000 miles, took it to get set up on the dyno and it will only rev to 9,300
the graph on the dyno shows it to fade away on power then come back to life so to speak, then fade away then comes back to life, the line is up and down.
i swapped the following parts over of the same year busa that was in for a service and runs 100%
ECU
Ignition coil sticks
Spark Plugs
All Sensors
Throttle Bodies inc pump
the graph line on the dyno is staight up from the off no dips or anything until it gets to 9,300 rpm
the other post stated he had the wrong valve springs fitted, yoshimura state in the fitting instruction you dont need these as their cams are just slot in but i have re-shimmed it head to 0.20 on both sides,
power is there from 1,000 rpm to 9,300 rpm there is not a problem, it just wont hit max revs ?
i have not fitted the power commander as its not running good enough to fit it due to this problem.
i was red lining no problem before the engine rebuild,
any ideas ? as i have run out of them along with money guessing and changing parts to try and fix it.
thanks
Bazz
yoshi stage 1 cams
new cam chain
ECU
Spark Plugs
All Sensors
thanks
Bazz
