I am having a 1363 kit installed later in the spring and have a few questions. I am curious what the consensus of opinion is.
Should I go with the Wiseco or the JE pistons?
Should I go with a intake cam on the exhaust side or new Web drop-ins?
The builders that I am talking to are claiming the same hp/tq numbers and the price for the build is w/i $110 of each other.
Before anyone says, "Why not a 1397?", here is the answer. I have done the research the 1397 bikes overheat and some can have starting issues. This set-up shouldn't overheat unless I am in heavy heavy stop and go traffic. We don't have a lot of that here and engine ice or water wetter will fix that. As far as the starting, a YTZ145 Battery is included in the packages and with ~100 more cold cranking amps, that shouldn't be a problem either.
I am looking for a bike that has more "UMPH" but I can ride it every single day and not worry about over-heating and whether or not it is going to start.
Thanks for reading and you guys let me know what you think.
Don
Don
