Bike Heating Up
I dony know why my bike heating so much....just bought a used 2010 Hayabusa.....i took delivery of thr bike and my home was 150 kms from there....even on highways the temp was at its highest point......then i met with a traffic i turned off the engine several time because the temp was showing high...after 5 times doing this as it was moving traffic....the battery was totally didcharged and bike wont start....then i found a mech and jump started it......please help me
Hi Pravesh, how about some more info? Did the fan ever come on? Fan switch fuse bad? Low coolant? Did you look at the coolant level in the overflow tank? Not sure why the battery would be low unless it's an old one.
Probably repost this in Busa problems: "https://www.hayabusa.org/forum/forums/busa-problems.34/"
If the bike is overheating on the highway, ck the coolant level, possible bad radiator cap, or thermostat stuck in the closed position. I would ck the thermostat first and go from there.
