I replaced fuel pump battery,starter clutch and still dosen't start.If I push the bike it will start and run fine.A guy was telling me this was a problem for 99 and 00 year.He said I need to update the starter, and gear like the 03.Could some one tell me what I need? thanks
Sorry I can't help you but I have a question. How do you push-start the Busa? I tried it in every gear and couldn't get it to turn. I never "had" to do it, but I have tried just to see if I can. Maybe I'm not running fast enough. How do you do it?
I would suggest putting a jumper wire on the plug that the dealership uses to down load codes.It should give you a code on the dash, it might save you some money.Hope that helps.
Hey sorry, I'm having the same type of problem! When the bike is hot it won't start, unless I use the idle or open the gas tank to relaease gas vapors!!! I just added a titanium case protector and I'm thinking about running another battery if necessary. Any body has a price on a 03 starter gear!!!!!
