Then it's the clutch switch, kickstand switch, starter button, starter relay or tilt/tip sensor.
Turn the ignition off and the kill switch off, have bike in neutral.
Now turn on the ignition and the gauges should run their cycle, now turn the kill switch to run, the fuel pump should now prime. If not suspect the tilt/tip sensor. Pull clutch in and push start button.
(If it's in neutral and not starting that takes the kickstand switch out of the equation.)
When you push the start button do you hear the click of the starter relay?
If so your clutch switch, starter button and starter relay are working and you'll have to investigate further on why the starter is not turning.
If you hear no click with the start button check your fuses. if they are good you will have to systematicaly check your clutch switch, start button and starter relay.
