Hi all, I've tried to balance the throttle bodies on my '07 gen 1 without success,I couldn't get it to tick over without revving it.So
I've given up,but now it won't start,it's turning over but not firing,it was ok before I started!!!Any ideas?
Hi, yes all the hoses are on the air box,and on the throttle bodies.Do you know what the small hose that connects onto the valve on the air box goes to?I sucked down it to try to get the bike to run before I gave up.
I think your talking about a vacuum switch...should be ok....did you reconnect its electric plug.
Is the fi light on when cranking it over...can you hear the fuel pump before trying to start.
Is the air temp sensor on the airbox connected.
