Jose J Ortega
Hey guys,
All this started about a week a go that I change the oil and clean the the engine. After cleaning the bike bike started. Then I left and 4 hrs later I try to start it and will just click. Later it started I took it for a ride to dry up . Bike was running good , I turn it off and and dint turn on. After pushing the side stand switch and clutch won't start . Then it started. Check the battery in a auto part they say is good. Check the starter relay and is passing 12.5 when I hit the start bottom. To discard the started I did the k3 starter green label and the k3 starting system. I don't know what else to check. Thank in advance
