bike won't start
tytan
I need some help. I have a 2007 i recently acquired n It won't start. I know it ran, a Little rough bc it sat up for about a year but it ran. I drove it about 2 miles back to my job n the next day it wouldn't start. I have replaced the fuel pump, sent out the injectors n had them cleaned and tested, a the battery Iis good. I can take off the air box and spray throttle body cleaner across the throttle bodies and it will run as long as I keep spraying. It seems like a fuel issue but I've replaced all the key components of the fuel system. I don'tknow what to do next.....
Tip over switch. If it's bad or not connected the injectors won't pulse. Therefore you can spray fuel in the tb's and it will run. But it won't run on its own.
I took the injectors and sat them over the throttle bodies to see if they were spraying and they were.
Would a clogged or restricted fuel filter cause it not to start? N where exactly is the fuel filter?
