i went out to start the bike and it made a clack clack sound when i hit the start button. then the starter stopped engaging it just wined and would not engage to start the motor.
Try charging your battery/or put a new one in it.At best a battery will last 3 years if ridden regularly.If bike is not ridden often,put a battery tender on the battery & it will keep it charged up between rides.If it is not a battery problem,you probly have a starter idler gear "binding"in its housing,or a bad starter clutch gear assy.
Starter clutch gone,don't play around with it as they are prone to crack cases and if it grabs and kicks back your in trouble.upgrade to new stlye starter system or install case saver while in there.It won't make it so easy to damage..
I have the same problem,I missed school today cause my baby busa wouldn't start,All I got was an awfull clack,clack,clack sound,let me know if when you get it fixed
