scooterlord
well, here we go. my first time to change radiator fluids and am outta money and outta radiator fluid so once more i am gonna need your help guys.
i read the workshop manual but still have a couple of questions. it saya to add engine coolant up to the radiator inlet, swing motorcycle and then add coolant again. radiator inlet is on the top right side of the radiator. doesnt putting coolant in there drain it in the reserve tank? :/ because it says to fill it UP to the radiator inlet. wouldn't that mean that the coolant reserve tank should be full first?
and i assume that when you remove the hose it says it drains both radiator AND reserve tank filler?
and then when it says bleed air while engine is on does this mean i just have the radiator inlet cap open and it bleeds by itself?
..any more tips are helpful guys, i need to go on a trip and the weekend has already started. expecting answers as soon as possible for me to go down and start the procedure!
<!--EDIT|scooterlord
Reason for Edit: None given...|1148735331 -->
