Hi all,
having a nightmare trying to bleed the rear caliper,
replaced all lines on the bike, and fronts have been difficult but ok now,
the rear wont bleed, have tried pressure bleeding from the reservoir down, have tried craking open the banjo bolts and have tried reverse pressure back through both the bleed nipples to push fluid back through the system,
the strange thing is that the little master cylinder does not seem to want to pump fluid through it, it does pressure the line and pump out the fluid that I have reverse filled, but wont suck new stuff.
I opened up the little plastic cover on the side and there are two little holes on the inside - obviously to allow fluid to get intot the piston, and one seems clear the other looks blocked by something,
losing patience and got blooming fluid everywhere !!!!!
any suggestions - my next plan was to take apart the master cylinder and see if there was dirt or something inside
all was ok before I replaced with new lines !
thanks
scott.
thanks
scott.
