YOu can make the brake bleed a one man job with a speed bleeder
Example. There are a bunch of different manufactures of this thing I got mine for 10 bucks each.
What it does is allow you to loosen the bleeder and then pump without fear of air going back into the system.
I have Might-vac as well and i think the speed bleeder is an easier solution.
Additonally, when you use the vac, you are effectively pulling fluid into the braking system fromthe resevoir. When you use a speed bleeder and pump the brake you are pushing fluid in. more likely to get all the air out that way.
