night_ryder
Ok, i have bleed the brakes on the rear caliper several times. In those several times, i have pumped the brakes a few times then held the brake and then bleed the brake. Then when i thought i wasn't getting anywhere with that i pressed on the brakes slowly while bleeding the brakes until the brake was held all the way down, then tight the bleeder screw.
After, doing the two different ways my brakes feel the same. What do i do know, will it eventually start working after i keep bleeding the brakes several more times or am in doing all wrong?
What i ever i need to do different or more please tell me because i'm confused at this point.
