Oh..ok...! Thanks!I have a stage 1 velocity kit on my bike with the HKS bov...A bov is not necessary on the stage 1 but that system can be upgraded to include one, the stage one simply does not make enough boost for the true need of a bov...But the bov really sounds good at high rpm gear changes...
I've had some major mods done to my bike over the winter and have not had it on the dyno yet...If you've got the money to blow you'll love the bov...Oh..ok...! Thanks!I have a stage 1 velocity kit on my bike with the HKS bov...A bov is not necessary on the stage 1 but that system can be upgraded to include one, the stage one simply does not make enough boost for the true need of a bov...But the bov really sounds good at high rpm gear changes...
How much HP does your system produce?
thanks a lot...I've had some major mods done to my bike over the winter and have not had it on the dyno yet...If you've got the money to blow you'll love the bov...Oh..ok...! Thanks!I have a stage 1 velocity kit on my bike with the HKS bov...A bov is not necessary on the stage 1 but that system can be upgraded to include one, the stage one simply does not make enough boost for the true need of a bov...But the bov really sounds good at high rpm gear changes...
Are you serious?thanks a lot...I've had some major mods done to my bike over the winter and have not had it on the dyno yet...If you've got the money to blow you'll love the bov...Oh..ok...! Thanks!I have a stage 1 velocity kit on my bike with the HKS bov...A bov is not necessary on the stage 1 but that system can be upgraded to include one, the stage one simply does not make enough boost for the true need of a bov...But the bov really sounds good at high rpm gear changes...
most probably i will install the bov, since i love that sound it makes. i will try contacting velocity just to double check.
question: how would you compare the power of a stage 1 to a stock busa?
Like Cecil said...Are you serious?thanks a lot...I've had some major mods done to my bike over the winter and have not had it on the dyno yet...If you've got the money to blow you'll love the bov...Oh..ok...! Thanks!I have a stage 1 velocity kit on my bike with the HKS bov...A bov is not necessary on the stage 1 but that system can be upgraded to include one, the stage one simply does not make enough boost for the true need of a bov...But the bov really sounds good at high rpm gear changes...
There is NOOOOO comparison between a Boosted Busa and a stock Busa.
A stage 1 kit is an easy 100hp bolted on... it makes a HUGE difference!
+ 2!Like Cecil said...Are you serious?thanks a lot...I've had some major mods done to my bike over the winter and have not had it on the dyno yet...If you've got the money to blow you'll love the bov...Oh..ok...! Thanks!I have a stage 1 velocity kit on my bike with the HKS bov...A bov is not necessary on the stage 1 but that system can be upgraded to include one, the stage one simply does not make enough boost for the true need of a bov...But the bov really sounds good at high rpm gear changes...
You must be in the process of purchasing a kit or you would have not asked that last question...
There's just no comparision to a stock vs bposted bike...Period...
That's why we keep 'em a coming...Knowledge...I just can't translate what I'm trying to say most of the time...However, I do know what I'm talking about...you guys are right, i haven't been on a turbo bike yet. just about done bulding a custom busa...will post some pix when done.....
