The fork seals are best done as a 2 person job, but is fairy simple and painless.
Traxxion Dynamics makes a spring compression tool that you MUST HAVE in order to take the fork apart. Or, if you are handy, look in the "Maintenance and Do-it-Yourslelf" section and look at CAT3's write-up about the "Fork Service How-TO", he makes his own compression tool in there, and is a great thread to go by!
Not sure if you plan on doing both forks or not, but if you've already blown one seal, chances are the next one is not too far away. May be worth it to go ahead and check the seals in your left fork as well.
How many miles you have on your Busa? Has the fork oil ever been changed?
You can expect to spend around $60 on both sets of seals for each fork (dust seal and oil seal). That $60 estimate was also including a bottle of fork oil. If you do it correctly and don't spill any oil, ONE bottle will do both forks, but i bought two bottles just to be on safe side.
Follow the instructions in the write-up, they are GREAT! And DO NOT loosen that Fork Damper Cartridge Bolt at the bottom of the fork unless you are wanting to remove the cartridge. Removing the fork damper cartridge is unecessary for what you are about to do.
Let me know if you need any help, or if i can send you my Traxxion Dynamics fork spring compression tool. I have already taken my forks apart on 2 different occasions now, no expert, but i believe in the motto "See one, do one, teach one"
Good luck!
