BMC RECHARGE KIT
bigpoppa1969
Sup Busa bros...havent been on the site for awhile now...Had to deploy. anyways... I have a BMC airfilter, I ordered the recharge kit, and guess what? back order lol...does anyone know if the K&N recharge hit will jack anything up?
any help here?
I already did help you but here's more .
The KN filter oil is Hydrotreated Heavy Pariffinic Distillate and less than 1% Methyl Benzene along with less than 2% Methyl Lardate . The two methyls are solvents .
The flash point is not less than 392 F so it's not going to ignite on ya
and with a flash that high the other chemicals in there are not " hot " enough to harm  jack .
Even the nearly pure  hydrocracked group II base oil is altered during the process to the point that all inherent solvency from the group I it was made from is lost in the process .
There are oils called Neutral Oils that are blended/used for this and that but this group II is as neutral as it gets in my view .
The cleaner is Sodium Silicate CAS # 6834920 . If it won't harm one cotton , it won't harm the other I'd think .
There ,
 we all go out of our way sometimes and this time was to help a shootist
So call and act like you want to buy a BMC Filter but tell them it looks like you need to use the KN stuff since their's is not available and ask if it's OK .
Then tell them some jerk
on the internet told you it was OK but you just wanted to double check
EDIT:
Forgot to fire a few rounds
<!--EDIT|mountainmotor
Reason for Edit: None given...|1125594526 -->
