Anti seize won't damage any specific types of metal?
This is from the CRC webpage info sheet . .
Anti-seize lubricants are specialty lubricants that reduce friction between threaded and mated metal parts as well as prevent corrosion and seizure of parts under pressure and at temperatures well beyond the performance of conventional lubricants.Esse
www.crcindustries.com
"Anti-Seize is a general purpose, high temperature anti-seize lubricant for protecting metal parts against rust, corrosion, galling and seizure at temperatures to 1800° F. It is silver in color and contains copper, aluminum and graphite. Because of fine grade fillers, Silver Grade is particularly suitable for fine threaded and other closely mated parts. It is not recommended for applications where copper is prohibited."
here's more info . .
One of the most important issues concerning the use of copper is the chemical reaction between copper and other materials. Chemical reactions are responsible for corrosion, staining, and even the green patina that develops on copper surfaces over time.
www.copper.org
"Since
copper has one of the highest galvanic numbers (or nobility) of the active metals,
it will not be harmed by contact with any of them. It will, however, cause corrosion of the other metals if in direct contact. ... It is not necessary to isolate
copper from lead, tin or stainless
steel under most circumstances."
"It is not necessary to isolate copper from lead, tin or stainless steel under most circumstances. The principal metals of concern in terms of direct contact are aluminum and zinc. Iron and steel are generally not a problem unless their mass is similar or smaller than that of the copper."
As far as I know, copper and steel are compatible.
