If you are running pump gas, your maximum boost should be no more than 8 pounds with a good tune. If you are running race gas (like C16), your max boost will be 10-11 pounds. At that level you will start running out of fuel, since the stock injectors will be maxed out. You can go higher, but IMHO it will not be "safe".
