Brake Caliper Cleaning.
trekfuel
Bike has about 10,000 Miles on it now.. and have noticed a slight discolouration to the front left brake disc. I figure is must be dragging a little so it is time to do Caliper Maintenance. Removed pads and disconnected Caliper from the fork tube... I have done the Soap and water scrub. The Caliper looks much better...
My question is before i put it back together what is the best thing to ensure it is dry? Brake cleaner spray? heat gun? or just take it for a ride?
Thanks in advance:beerchug:
Careful blow it out with low pressure air and let it dry overnight is the best way.
if its binding, u might need new seals. Cal rebuild kits are about $55 per cal. comes with 6 pistons, 6 seals, and 6 dust seals.
