ottafish
Been reading a few posts lately on brake calipers which started me thinking again.. (I've had this discussion with myself over the years..)
What makes one brake caliper better than another?
If a name brand caliper is 15% better than an oringinal, factory oem unit, but is 60% more expensive, is the gain worth the financial outlay?
For the amount of time a rear caliper is used, does a replacement to a name brand make sense if the oem factory is up to doing the job?
A brake cailiper is not much more than a hydraulic ram.. Fluid goes in, flows through some channels, and pushes onto a piston, which pushes pads to the rotor.
If that's the case, what is the differences in design that make one brand caliper better than another? Don't they all follow the same design brief?
I understand there are 2 (or more) piece calipers and single piece calipers, which is an obvious difference, but surly if single is superior, then ROi on mass production would bring the cost down? No? Think of things that have started in F1 world or high end cars, then progressed down the line to where it's commonplace now.. ABS, cruise, elec windows, A/C - they all were expensive options at one stage.
Don't get me wrong, I know there is differences, put a brand name on a factory bike and watch the press reviews go all gooey over them.. But the question is, why?
The more complex a thing is, I can understand the differences, cheap run-around cars vs the luxury imports, solid name brand tv's vs the cheap imports..
But they have many, many parts.. A brake caliper has at most 6 (pistons)
Just look at the name brand on our bike; 4 moving parts.. Plus some rubber seals.. Fluid goes in, thru some channels and pushes the pistons out.. Thats it..
Daydreaming rant and rambling over
