So I inspected front pads. 3.2 mm avg thickness after 3200 miles. Anyone know what new pads oem are? I get tons of brake dust so I know they wear quick. Anyone replaced theirs yet?
Yea so heres the big issue. No one is listing stuff brake wise for Gen3 unless I am totally missing it. Even in the service manual theres no recommended min pad thickness either. Really curious about the thickness of new pads compared to what i have now.I have the EBC HH Sintered Pros and they seem to last forever, I picked up another set as I noted the set in the bike were looking thin...the new set aren't much thicker.....
I can't see you needing new pads , unless you have been using it around the race track for 3200 miles,So I inspected front pads. 3.2 mm avg thickness after 3200 miles. Anyone know what new pads oem are? I get tons of brake dust so I know they wear quick. Anyone replaced theirs yet?
I am alot of stop and go daily driven miles.I can't see you needing new pads , unless you have been using it around the race track for 3200 miles,
Mine lasted a long time , 15000 or more miles but I am light on the brakes
I am keeping an eye on all things brakes just incase. With folks loosing "pedal" before riding I want to keep an eye out.Plenty. Something up with the inside pad.
So I ordered my pads man. I am down to 2.5mm from 3.2 mm when I made this post. When I get them I will give you new VS old measurements. 2mm is the recommended replacement thickness. Minimum by state inspection is 1/16th inch or 1.6 mm . What has me is look how far out the pistons are on this.Have a look at some pads in a dealers ,you wil see there's not much meat on them to start with. Take a photo to let us see and there is a wear indicator on them also
I checked the EBC HH Sintered pads I have on the bike and thought I had better order some new ones and replace them...when the new ones arrived, they weren't much thicker than what I had on the bike....So I ordered my pads man. I am down to 2.5mm from 3.2 mm when I made this post. When I get them I will give you new VS old measurements. 2mm is the recommended replacement thickness. Minimum by state inspection is 1/16th inch or 1.6 mm . What has me is look how far out the pistons are on this.
Just the way they are. Nothing out of the ordinary.Plenty. Something up with the inside pad.
