BBBUSA has an extension swingarm with a block as you describe to hold his caliper too but its on the bottom side or his swingarm. I dont see why you couldn't just flip it over on top . If the carrier block can rest evenly on top of your swingarm and you have enough slack in your brake line to reach the axle, you should have no problems.
<!--EDIT|Rhythm
Reason for Edit: None given...|1152424359 -->
Might sound like a good idea until you hit a pothole or emergency braking is needed. I would say bad call, unless this is just a show bike and you are never going to ride it in the streets.
