Brakes question.. another dumb question
TonyMastodon
Big Blue Burrito!
Im starting to get a little slight brake squeal at low speeds (you can hear it when you're not on the break what so ever)... but will go away if i tap it. (front breaks)
but at higher speeds (over 30), I dont hear any at all.
Is this something i need to be worried about???
There was an article in Popular Mechanics about breaks squealing on cars. It has to do with the weight of the pad causing it to resonate at a high frequency.
There fix was to glue the pad to piston so the weight went up and the frequency went down to an inaudible range.
Seems like a lot of work to me. You have to use a special high temp glue.
