So would I need s torch to get it that hot ?
Or would any map gas or butane work also?
Any local places sell that kroil like auto parts or Home Depot?
This will seem odd but I guarantee that it will work. Heat the plug til it is white hot, like almost sparking off, then quench it with running water until it is cold. It will come out.
I do this but normally don't quench the part. Normally just getting it hot is good enough to break the bond. I also weld nuts onto broken studs or bolts and the heat of welding is enough to loosen those as well.
