Broke the drive/output shaft on my bike...Any suggestions on an upgrade to a stronger shaft???If I go with a stronger shaft do I need to do anything else to the trans??? (tear drops)...
I had a few issues that I was trying to work out with the bike and ended up snapping the shaft...Man it just sheared right off...Of course broke the cover but nothing else...I was blessed that the chain didn't catch just rolled to a stop...The bolt ons I have on are flexing and the increased torque were not a good match...
the stock shaft will hold quite a bit of HP
I think you need to check to see whyit broke tight or loose chain misalignment. you could go with the billet shaft but it is $$$$
