After many $$$ going thru the motor (new bearing, forged turbo pistons, cam chain, porting and valve job, etc) it ran for 5 seconds then popped and died. Subsequent attempts to start it went no where. I did notice that it sounded different, like there was not as resistance to the motor spinning. I pulled the cam cover and found out 3/4 of the intake cam was not spinning. Pulling the caps I found the oem intake cam had broken about 3 inches from the cam sprocket. When I had Star Racing do the valve job they also installed new Carpenter Racing springs. Could that have caused the cam to break? The bike had 40K miles before the rebuild. Should I replace both cams? New or used cams? Any input is appreciated. Thanks.
