The studs are hardened steel.
The nuts are steel.
and Titanium because it has a fancy finish and looks cooler than aluminum, lol.
and use a small amount of anti-sieze
Titanium Nyloc Rear Sprocket Nut Kit. To FitSuzuki GSXR1000 Models from years2003 - 2004. Suzuki OEM part number 0831931107. NOT genuine Suzuki parts, OEM part numbers are supplied for indicative and comparison purposes only.
Titanium Drive Stud Kit For BST Wheels. Replaces the standard steel drive studs for BST wheels. Saves 40% weight. Made from grade 5 titanium 6AL4V This kit comes with titanium nuts also for additional weight savings. Kit comes with 5 pins and 5 nuts Sizes are: 10mm x 50mm x 1.25mm 10mm x 35mm x...
