Buell footpeg mod is done
bigjohn141
I just finished doing the footpeg mod and I must say OMG!!! I really didn't think it would make a whole lot of difference but i was wrong. I just thought the busa had leg room before. To top it off they look really good. Here is a pic or two.
very nice... more comfortable on long trips or just a better drag setup? How much did it cost you to do it? It looks great...
CLoud
What did you use to shim the center pin on the pegs? Did you need to do anything else to get them to fit?
I could sure use more legroom...
I did it for long trips because there are not a lot of twisties around here to worry about dragging pegs on. I actually used some brass fitting i had laying around to shim the hole. I drilled them out and cut them down to fit. They seem like they are going to work great. Some of the other guys around here use TL 1000 peg bushings. I had to adjust my shifter with consisted of moving the clamp on the shifter rod clockwise one tooth, which was perfect. I also had to adjust my brake up all the way. I think I will shorten the rod on the brake to get a little more out of it. Total cost was $31.65. Here is a link to a online source of the pegs BUELL PEGS and here is the orginal thread which goes into the install a little more
